Mark A
Hi chaps,
I have a little problem with a wobbly floor.
The old screed is awful (cracked and undulating) and the difference between the peaks and troughs is 20mm or so in some places. It's also not level.
Plan A was to grind off the high spots and fill in the low spots with something like tile adhesive. Yesterday I had a go at grinding a section and it turns out the screed is actually just a 1/4" thick crust over rough concrete. Over to Plan B.
What is Plan B?
I refuse to take up the floor and lay a new screed as I don't have the time for such drastic work.
Self levelling compound is not an option either, as the existing floor is neither level or flat, so it would raise the floor up more than I'd like. And to cover 38sqm at depths up to 20mm will cost far too much. And I'm crap at laying the stuff.
Any suggestions?
Cheers,
Mark
What is Plan B?
Any suggestions?
Cheers,
Mark
