No skills
Hi all, quick and hopefully easy question for you. I need to replace and add in some extra floor joists upstairs, is C16 grade timber good enough or do I need C24 to meet building regs?
Ta!
Ta!
In this case probably correct Bosshog but not as a general statement. At least not in England though I'm not sure about the Scottish regs.bosshogg":37u34z9u said:First off you don't need to meet the building regs for repairs to your own house
That's the ones, the gripping action joins the two joist timbers together is if one piece...bosshoggNo skills":4c1mir3d said:I'm assuming the double sided connectors are the round washer type things with teeth either side?
