al3ph
Coles jaws, sanding.. You can probably fill in the blanks.
Bit of blood, and two very sore fingers, luckily nothing broken, probably a good idea to see if theres someway of covering the buttons to stop this happening again, and yep I probably made the mistake of applying to much pressure on the sand paper hence the slip.
Won't make that mistake again, I'm assuming I'm not the first to come a cropper like this?
Anyway back to the iced water
