First attempt at something practical
procell
23 Jul 2013
london
Whilst watching my son try to chisel a recess into a piece of pine the other day using a small plastic mallet I had a sudden thought. Why not make a mallet with a little more weight?
I had some sycamore branches I found at the end of my garden from when we trimmed a tree a couple of years ago so with a piece of this in hand I set off for the shed. Attached are the results of my first effort to make something other than just practice spindle turning.
Not sure how well it will stand up to being used yet. Is sycamore a good choice for something like this?
Nice job! You've identified the problem in terms of drying, but it's a nice bit of spindle turning nonetheless. You know what to do to avoid the problem next time!
Ian
you answered my next question before i asked it Finneyb.
I will give CA glue a try. Do i need to add sawdust as a filler?
I wouldn't bother the sawdust, too messy. Just run the glue in, and leave it long enough to cure fully. You might need to add the glue in stages depending on how deep the cracks are.
Nice bit of turning. (hammer)
I would only use sawdust or even dried coffee grounds for cosmetic reasons ie if I wanted to sand it smooth and add a finish.
In this case, as stated above, just run the glue in. Needs to be thin CA, it comes in different thickness.
Brian
To answer your question about sycamore, it's probably a bit soft for a mallet.
They are usually made of apple (heavy and hard) or beech but since it was free and you enjoyed making it then you can always make another.
On the bright side it's unlikely to damage the chisels :wink:
Not really - it's not really hard enough to stand up to much wear as a mallet. Harder woods like holly, apple, even hazel would be more durable. Having said that, though, they are even more likely to split than your sycamore! Sycamore is very good for items that will get used in a kitchen with food as it's a bland wood that does not impart any taint to the food. Sycamore is also fairly easy to turn and finish and a good wood to practice with.
Thanks for all the advice. I am learning a great deal of useful tips from you guys.
Its nice to find a skill where people are not afraid to share their experience with others. :D
