wizer
- Joined
- 3 Mar 2005
- Messages
- 15,589
- Reaction score
- 1
Following on from the cross cut sled thread. I'm going to take the TS200 back to basics and (hopefully) get everything aligned and running true. Then I can build the sled knowing everything is set up right.
I thought I'd document it here for both help and to help others who may have this saw.
I'm going to spend the next few weeks getting this saw sorted. I can't afford to buy a new one and I'm not sure I could fit a bigger saw in my workshop anyway, so I'm going to do as much as I can to get this fixed up and running true. Here's a list of what I'd like to do:
Clean underside **Done
Lube
Align Blade to Slots *Done
Make some sort of cover for the lateral adjusting screw.
Fix AM Fence and align
'Invent' a way to quickly remove and replace Guard
Make a dust hopper for the underside of the saw and plug all the holes in the frame.
Bump Start Switch
ZCI
Make a rolling cabinet which incorporates a router table (Like LarryS did a couple of yrs ago)
Push Sticks
Sleds
Feather Boards
Then I'll realise I can't live with it, sell it at a great loss and buy something else (repeat ad infinitum)![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So today I cleaned up the workshop a bit and started taking bits off the saw. I took off the fence rails and the side panels. Then hoovered it out as much as could, before taking to it with the airline. It still needs cleaning, but any loose dust has been removed.
I then made a 'jig' to hold the dial guage in the mitre slot. With one tooth marked I set the plunger on it and then rotated the wheel towards the back and took a reading on the same tooth.
Front Reading = 0:
Back Reading = -75:
Now. I must admit that I'm not sure how to read the dial gauge. Is each division 0.01mm ? 25 divisions = 0.25mm Is that a lot?.
If my guesses are right, is this enough to worry about?
Should I check runout on the arbor\nut?
Lube
Bump Start Switch
ZCI
Push Sticks
Sleds
Feather Boards
Front Reading = 0:
![DSC_0409.JPG](https://proxy.imagearchive.com/8f0/8f039f291c58dceffb915c2967f590a3.jpg)
Back Reading = -75:
![DSC_0412.JPG](https://proxy.imagearchive.com/b02/b02858841d7e3efbb12a2595c0af8305.jpg)
