segovia
I bought my Festool circular saw at the weekend, when I sit it on the 1400 guide rail the blade is right above the plastic strip that edges the guide rail. What am I dong wrong !
John :roll: :?
John :roll: :?
JanneKi":29knhypf said:That's right - that's how it should be. The user guide details the instructions, but you are now supposed to trim the plastic trip. Dial speed to 1, set depth to 6-7 mm and run the saw over some sacrificial board/ply/MDF to trim it. After that it shows you exactly where the cut will be made.
Over time, the plastic trim will wear and you will need to replace it - you also need to trim it again at that point.
I strongly recommend you read this manual:
http://www.festoolusa.com/media/pdf/ts_55_eq_us.pdf
segovia":2f73v7e5 said:Thanks, that explains it.
But I have to ask the question why isn't an instruction manual included in the kit !!!!! or are they and mine has gone AWOL
Begs the question what else is missing
The Wood Butcher":3hp4ebzu said:segovia":3hp4ebzu said:Thanks, that explains it.
Yours has gone AWOL but frankly you're not missing much. The Rick Christopherson manual you got a link to above is far better, and he does one for the OF1400, google his name and festool.
