Jamied
Evening everyone,
I am installing a ducted extraction system in the Workshop.
The fan has a 125mm inlet on the extractor and I have installed my ductwork the same size going as near to my machine's as I can, blast gates, straight Run's, gradual bends, short 100mm flexi to each machine.
All good until I got to my sedgewick table saw.
It has a 125mm outlet at the rear and a 40mm from the riving knife blade guard.
Should I branch of to the top of the machine and continue to the rear in 125mm pipe , or reduce to the rear in 100mm to compensate for the overhead branch.
The main duct so far to the saw from the fan is about 3 metres , needing to go another 2 meters to the back of saw.
Your help would be appreciated.
Jamie
Jamie
