I recently did an oil & filter change on the Focus (TDDi). I do it quite regular (every 6 months or so), unless it's going into the garage for something and then I get them to do it.
Anyway, I did the usual routine, put the fresh oil in, then took it out for a little run to get it all flowing and in the filter etc before topping up to its final level. The engine holds 5 litres, the filter 0.6 litres, so I normally put 5 litres in then top up.
Sounded a bit rough. So I got back, only to find that there was hardly any oil on the dipstick, and it was way below the "minimum" level. The problem - I had put in a full bottle of oil, which is 5 litres. Or so I thought. What I hadn't realised was that this oil was only 4 litres! Strangely the Oil Pressure light hadn't come on.
I topped it up to its right level, but it is still sounding a bit rough - it also seems to have lost a bit of its acceleration in the lower revs. And it can chug a little bit of you cruise in a low gear (eg. going round a corner in 2nd). It wasn't like this before.
The oil was 5w40. The manual says you can use this, but the recommended is 5w30. Would changing the oil to the lower viscosity reduce engine noise?
I also changed the fuel filter at the same time, but that went fine (although i've never done it before and was following a manual).
Any suggestions?
Karl
Any suggestions?
Karl
