Sheptonphil
Scrumpy junkie
I have my dust extractor located in an adjacent room. The intention is to automate the powering on and off of the extractor at each machine in the ducted system.
The electrics are going to be hard wired to each blast gate with thin bell wire so the DX powers in when the blast gate is opened and turned off when the gate is closed. The bell wire is taped to the back of the 4” pipes and is not seen anywhere. I have today installed all the wiring to seven blast gates and the system works perfect.
The total cost of the complete kit of components is a tad shy of £30.
The DX is a 1.5hp induction motor and as such solid state relays are unsuitable, so a twin pole contactor relay was used. This relay will switch up to a 3hp motor.
Here are the components, total about £30
relay contactor two pole for total isolation, they’re listed as used, but in fact are new without a box £8.50 (I paid £6.50 four days ago)
microswitches Pack 10 £3.69
12v transformer £4.29
bell wire 100m £9.99 or 30m for about £4.00 I bought 100m as I’ve further projects In mind
Enclosure sealed against dust £4.79
Glands not essential, but finishes the job
the system works by utilising 12v micro switches on each blast gate that trigger the relay when the gate is opened. All the 12v switches I have wired in parallel, but could equally be wired in a radial, or combination if that was more suitable for your space.
G7L 2A T two pole contactor relay and 2A 12v transformer to supply switching
checking fit of components
All terminals have been soldered and shielded in mine, but well fitted insulated crimp terminals would work
Plenty of room in the enclosure. All terminals soldered and insulated except earth which is wago.
I ran the transformer for four hours, then removed the cover, there no noticeable heat generated. Will check in the morning.
Control box fitted on DX mounting board. I have use a switched removable plug so I can guarantee electrical isolation if I need to put pinkies anywhere near fan unit.
for now I have put a standard light switch at each machine as the micro switches haven’t arrived yet. This proves the working state of the system. You could use missile switches so it doesn’t get turned on accidentally. There is only one pole of the 12v circuit in the workshop so there is no danger of shorting anything.
I have drawn up a wiring diagram, it’s not overly complicated.
![2F4AAE12-3891-4F5D-9B26-07E2EB419D23.jpeg 2F4AAE12-3891-4F5D-9B26-07E2EB419D23.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75986-2F4AAE12-3891-4F5D-9B26-07E2EB419D23.jpeg)
![5AA9F3BB-3633-4636-B016-03D29762B738.jpeg 5AA9F3BB-3633-4636-B016-03D29762B738.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75987-5AA9F3BB-3633-4636-B016-03D29762B738.jpeg)
![C3DA9B91-22DE-4756-9A38-8BFD0D97968C.jpeg C3DA9B91-22DE-4756-9A38-8BFD0D97968C.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75989-C3DA9B91-22DE-4756-9A38-8BFD0D97968C.jpeg)
![9FA4B7C6-BEC8-4CDF-B6ED-685ED4798012.jpeg 9FA4B7C6-BEC8-4CDF-B6ED-685ED4798012.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75990-9FA4B7C6-BEC8-4CDF-B6ED-685ED4798012.jpeg)
![C3F73079-9899-4B84-8C49-7F7260F2A612.jpeg C3F73079-9899-4B84-8C49-7F7260F2A612.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75991-C3F73079-9899-4B84-8C49-7F7260F2A612.jpeg)
![6DF38329-9F3D-4FE1-AE79-B73CCDA3CC2B.jpeg 6DF38329-9F3D-4FE1-AE79-B73CCDA3CC2B.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75992-6DF38329-9F3D-4FE1-AE79-B73CCDA3CC2B.jpeg)
![C019F657-A03A-4409-B087-BD4337965E2F.jpeg C019F657-A03A-4409-B087-BD4337965E2F.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75993-C019F657-A03A-4409-B087-BD4337965E2F.jpeg)
![EDB45D25-D257-4EC1-B7CE-D85831DD2229.jpeg EDB45D25-D257-4EC1-B7CE-D85831DD2229.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/75/75994-EDB45D25-D257-4EC1-B7CE-D85831DD2229.jpeg)
