HRRLutherie
I'm in the midst of my first guitar build, and the saw dust is flying. Almost every surface is covered in a good millimetre or two of dust, and the floor rustles with chips and shavings. I also use a twin cartridge dust mask whenever I'm in the workshop, even if I'm just getting something. I'd like to feel a bit safer around the place, and try to stop sawdust from clogging up my tools. As such, I've been looking into cheap (but effective) dust extraction systems. I don't fancy the chip collectors with filter bags, as the hobby ones, such as this one:
http://www.axminster.co.uk/axminster-hobby-series-awde5002-extractor-prod886589/
only filter down to 30 microns, which means that it would be capturing the heavy stuff, and just spread the stuff that's actually dangerous (the sub 5 micron stuff). So, I was thinking of getting shop vac (maybe as small as a Henry Hoover) fitted to a cyclone. However, I could spend a bit more, and get something like these:
http://www.axminster.co.uk/numatic-numatic-nv750-workshop-vacuum-extractor-prod782719/
Then, I got thinking of CamVacs. Are they any good? Are they too noisy? Since they have 3 filters, would they require a cyclone to keep the chips at bay?
And then, I came across this on ebay:
http://www.ebay.co.uk/itm/DRAPER-40...17?pt=UK_Home_Power_Tools&hash=item43bc3a6e81
Does anybody have experience with this? It claims to have an integral cyclone, but can it's efficiency compare to a standalone unit?
Also, apart from capturing dust at the source, I'd like to also just generally clean the air in the workshop, so that it's not a toxic zone. I was thinking of one of these:
http://www.yandles.co.uk/product.php/section/6496/sn/MICMC100
working in conjunction with one of the systems above. For a workshop the size of mine:
http://i.imgur.com/10hQtNbh.jpg
http://i.imgur.com/7FuPj2Gh.jpg
Finally, although at the moment, I don't have a planer or thicknesser, I would like them at some point. My router spews out some pretty hefty chips, but should I get an extractor with a 51mm inlet, or one with a 100mm inlet.
Thanks in advance, and sorry about the long post!
