Hi all.
I really tried not to ask.. I'm sure it can be a tedious subject that has been much discussed but I've been going round in circles and can't decide! So some advice pleeese.
I have a 2hp HVLP blower venting to outside. It has 5" in and out ports so i have been looking at what 5" pipe and fittings are cheap and available online. All i find is extractor fan duct (rigid and flexi), and a very limited range of fittings.
It seems the easy and cheap option is to use 110 soil pipe and fittings (really cheap from jtm plumbing,by the way), but after reading tons about DE design including Bill Pentz, perhaps bigger ducting would pick up fine dust better.
6" seems too big for my small and simple design, but 110soil might be a bit small!?
It is worth noting that from DE port to TS port is only 2metres (under the floor) same for the 16" bandsaw. The thicknesser is a bit further from the DE, bur i find 4" flexi pulls the shavings well.
So heres my question..
Do you think it is worth using 5" for such short runs? (With limited fittings and more need to use flexi)
..or use 110 soil pipe (with large choice of fittings so a more slick efficient design)?
5" looks a lot bigger than 4" : )
Many thanks,
Jules
Many thanks,
Jules
