blackrodd
I can get belts made for my Kity K5, but the makers need a belt as pattern and confirmation on the RPM of each belt.
Now, as I have none spare, should the belt get lost in the post, or get mislaid, then I'm stuffed!
I was given this link for drive belts for the kity K5, by Dhenry, They are a french stockist on fleabay.
Dhenry asked for some feedback on my purchase.
http://www.ebay.co.uk/itm/370094320811? ... EBIDX%3AIT
Everything about the buying and paying, was easy as usual, belts arrived in 3 days and not a bad price for an obsolete machine, as the machine is useless without the belts!
They have drive belt listings for several other machines as well, So should you need the small, slower saw belt,( 710 mm x 15mm wide) belt, or the planer feed belt,( 530mm x 6mm wide) which is the only ones for the K5 they had.
Or any other french machine, try here, above, press look at other items.
They give the belt length, width etc.
HTH Regards Rodders
HTH Regards Rodders
