Drilling aluminium
RobinBHM
17 Sep 2011
Wst Sussex
Im making some jigs which will require some holes drilled. It would be nice if I could drill clean, round holes rather than wood butchered ones I usually end up with :D
16mm diameter holes in 6mm thick aluminium.
Would a 16mm starrett work?
http://www.ebay.co.uk/itm/252089593019? ... EBIDX%3AIT
Also 6mm countersunk holes for M6 allen socket screws. Will a normal hss drill be best followed by a csk?
Can I use a piloted csk or centre drill in a pillar drill? I hate when countersinks go off centre and chatter badly leaving a dog chewed mess!
TIA
Robin
Aluminium can be quite easily drilled with HSS or cabon steel bits. easiest in a drill press if you have one. you can get 16mm drill bits with a reduced shank or you could use a holesaw like you link to. Use paraffin or WD40 as a cutting lubricant. HTH.
Sent from my SM-G920F using Tapatalk
I wouldn't use a hole saw, it's likely to make a mess in aluminium alloy that thick. I'd drill it in stages with at least three or four drills. Something like 6, 10, 13, 16mm. My largest plain shank drill bit is 16mm but if your chuck doesn't take a bit that big then as said reduced shank blacksmiths drills are available or you could use Morse taper bits. I normally drill alloy dry but paraffin is a good lubricant if needed. I use plain counter sinks and don't have any problems. The fewer the teeth the more cleanly they seem to cut. "Snail" counter sinks work quite well although I think they're really designed more for deburing. To avoid chatter run the drill as slow as you can.
For metal, you need a different countersink from wood. Wood c/s have many cutting edges, like a star, metal just one. This helps prevent chatter and corrugated holes.
Keith
Many thanks for all the advise.
I think I shall try a 16mm blacksmiths drill in the pillar drill, starting with smaller sizes and working up. A bit of white spirit for lubrication as well.
Ive got a csk bit with 4 cutting points, so will have a go with that.
Cheers Robin
If you have access to a pillar drill and you have clearance under the metal, then a step drill is a very good option.
They will drill and shallow countersink at the same time, and cut very clean and fast. All they require is baby oil and because of the large mass they resist overheating.
I have just drilled a hole in 1/4" 6.35mm aluminium to demonstrate - pictures attached.
The bit is an imperial version that cost less than £2 off ebay.
My pillar drill has shocking run out front to back, it rocks 0.5-0.75mm but with this bit, it still works. Also the break out on the other side is very slight, much less that with a normal bit probably due to the side cutting action of the bit.
Many thanks for that oakmitre, Ive always thought step drills were a bit of a gimmick, but the image certainly shows a very clean hole to my eyes.
Cheers Robin
Cheers Robin
For some reason which I don't understand the recommendation for metalcutting countersinks is to go with an odd number of flutes. This has been borne out by experience for me - I have three, four and five flute cutters and the three-flutes are the easiest, followed by the fives. The four flute is fine in wood, but chatters like mad in metal. Another thing that no-one has mentioned is workholding. You will increase your chance of getting a clean csk if you can clamp your workpiece securely to the drill table. What seems to happen if you don't is that one tooth (inevitably) hits first, the workpiece moves slightly and from then on its a fight between the teeth.
Rob.
