Drilling a concrete wall.
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
I'd like to drill a hole in the shap wall around 50mm.
Its just a single block wall, I can't really measure it but prolly 6 - 8"
Should I hire equipment for the task or purchase a core bit and use the corded drill.
I've been told not to use hammer drill with core bits?
I agree with the advice not to use hammer action with a core drill.
On a lot of older style hammer drills you can turn the hammer action off (this isn't a feature of many SDS drills though unless they are the multipurpose ones with interchangeable chucks).
I would buy the cutter and have at it with your corded drill. 50mm isn't that big, just don't lean on it too hard and make it bog down.
In the past, I have used a big impact driver with core bits in stone. The bits are the ones with discrete TCT teeth. There were no problems. Some holes were through about 0.5m of stone. I have used the same on brick as long as the wall will withstand the impact. Some bricks are so hard I couldn't get through them without impact Some old walls have lime mortar which will not withstand an impact driver. The wall starts to disintegrate. I have never tried the diamond core drills. That's what I would try now and no impact.
The difference in density between different walling will impact on the type of drill and bit selection.
It may be worth just drilling a small - 6-8mm - hole with a normal masonry bit - you will then know what you are dealing with. Could be a simple cordless dril and job done in 15 mins, or hire a rig, special bit, spend a couple of hours.
I drilled a 50mm hole earlier this year- borrowed a hole cutter, and drilled it. Very easy, just allow plenty of time and don't let the drill heat up. I used a basic corded SDS, but any drill should be able to do it in time. Turn the hammer action off. A small masonry chisel is useful for clearing the centre out.
Apart from the drill over-heating, the other risk is your wrist being caught when it catches, so go carefully, not too fast.
This was a 1970s concrete wall, so fairly tough.
