Drawer fronts.
Roxie
20 Sep 2011
Bedfordshire
I am making a multi drawer jewellery cabinet and stuck as to how to join the drawer fronts to the sides. The largest drawer is 2 1/2 deep by 7 ins. and 1/2 thick the sides will be about 3/8., and they are inset. The obvious joint is the stopped dovetail (I think that's the right phrase) but they would be rather small and I am not sure I have the skill!
Could someone suggest another joint. I have looked in Joyce's book and he shows a joint that could be done using a router, a sort of groove and tongue, discuss!!
Any help would be most welcome
marcros
11 Feb 2011
Leeds
What about a dowelled version of the domidrawer?
Sorry on phone so can't link easily, but it is a pinned rebate joint. Plenty strong enough for a jewellery box.
Roxie
20 Sep 2011
Bedfordshire
Thank you tyreman I gave it a try and as you say not too difficult.
I looked at Paul Sellars and followed his tutorial with a couple of refinements. I used "blue" tape on the drawer front as it made it easier to see the lines on dark wood. I removed the portion of tape in the section of wood that needed to be removed. I did see another YouTube where the presenter used an old cabinet scraper to "cut" down the saw kerf at the back of the dovetail. It made it easier to clean out the back corners. Done two sides, so far so good.
Thanks again
katellwood
2 Jan 2007
Near Dartford, Kent
why not cut a through dovetail then glue a piece on the face to form what would appear at a glance to be a lap dovetail.
woodbloke66
17 Sep 2018
Salisbury
2.5" or about 63mm in 'new money' isn't too bad for a set of two dovetails. My suggestion would be to find some decent softwood (look for pine with tightly spaced annual rings..it's out there, but you'll need to look for it) and make a few practice joints. They're not too difficult and the the 'blue tape' tip is a good one - Rob
Benchwayze
10 Mar 2007
West Muddylands
I have tried that myself just for the heck of it on a box for the shop. It was OK, but flattening the two mating faces took a little time.
John (hammer)
