Mikey R
Hi,
Im in the process of building the legs of a bench, laminated from B&Qs finest softwood 2 x 4s. The legs are approximately 90mm x 115mm, the stretchers are approx 95mm x 40mm with 18mm thick tennons on the ends. This is my first bit of real joinery, and Im quite pleased with the result so far. I will be drawboring the tennons into the morices in the legs, but I would like some advice on what specie to use for the pegs.
The options from the offcut box are either hard maple, american ash or black cherry.
I am leaning towards cherry pegs, in 10mm holes, offset by 2mm or so. I suspect that the harder, stiffer maple and ash would do more damage to the soft pine than they would help.
Does this sound reasonable?
