RogerS
The problem...
Making six longcase clock cases. The backboard is nearly 2m long and 350mm wide. Lot of work gone into making them, let alone the cost of the exotic hardwoods. At the top, is a small horizontal panel (for want of a better word) that spans the width of the backboard and needs to be dovetailed in place using a few chunky dovetails.
Normally I'd stick both pieces of stock in the vice and do them by hand but at 2m long that wasn't practical. Options were to lay the board horizontal on my table saw, climb up on top and do the dovetails vertically. I wasn't too enthusiastic about doing that. Not that the table saw would not easily take my weight, just that I wasn't convinced about the eye-hand co-ordination with everything re-oriented let alone not being able to use any of the various dovetailing jigs, aids, mirrors that I sometimes use.
Option 2 was to use one of the various jigs available on the market although I had my reservations about this approach as well since the router would have to be held square and true in the vertical direction and on all the jigs I saw there didn't seem to be enough landing area to give the router adequate support. I did buy a secondhand Leigh jig but in my naivety discovered that it wouldn't cater for boards of the thickness I was using so that idea was scratched.
Still humming and hah'ing, it was surprising just how much displacement activity I could find rather than bite the bullet and 'do something'. Further research suggested the latest Leigh D4R with the optional vacuum/router support would fit the bill but at £600 a bit eye-watering.
As serendipity would have it, I was discussing my dilemma with DaveR (Dave Richards of SketchUp fame) and he thought that he had a solution. This is what he came up with
Looked very very promising. Lots of MDF dust later, I came up with these two.
Time to put them to the test. Thank God for a fully retractable table saw blade and riving knife. Board clamped down firmly, jig in place, router set to Go.
Initial cut made with a straight bit to reduce the workload on the dovetail bit and then the dovetail cut. First cuts made.
Carefully clamp the top panel in place to mark up. I use a knife tight on the inside of the tails to mark the line of the pins on the top panel. The trouble I had was that bubinga is very hard and dark and I found that the knife lines were not very visible once I got them in the jig. To get round that I laid masking tape down the edge of the top panel and marked that up. Worked well.
Using bearing guided trimming cutter for the pins I started to make the first cut. Then the Cock-Up fairy decided to lend a 'helping hand' as I forgot I was using a bearing guided cutter, decided I was uncomfortable hogging out the complete cut in one go and so raised the router cutter, lost the bearing reference surface and gouged out the jig. Epoxy and judicious filing and several hours later ready to go again.
This was when the F***-Up fairy though that it would join in the fun as yours truly started to rout out the wrong side of the line....
Remedial work done to the top panel and pins cut.
Offer up the two pieces together to test the initial fit and looking good. Bloody Hell. It works!
Bit of careful filing and jobs a good'un. Just need trimming down the excess.
Huge Mega-Thanks to DaveR for the original idea.
