well, DW decided that she would like to make a box to hold a christmas present for a good friend of ours, a dovetailed box to be precise.
In my eyes this would have been a hand cut, reasonably "rustic" affair but she wanted perfection....
I went and bought a router and dovetail jig (Trend CDJ300 - got it for a bargain at my local B&Q £25!!!)
I set up the jig and show her how to switch on the router, about cut direction etc.
First set of cuts is pretty close, needed to adjust the depth of cut a bit as the joint was a bit open.
Second set was much harder work apparently and she stopped and gave me a shout. I thought it was just hitting a hard knot or something in the oak.
I push on through and it goes fine.
pull the wood out of the jig and make this face :shock:
I had neatly routed 6 1/4" round grooves in the base of the jig.
Stupid collet had slipped and the bit dropped down a fair bit.
I thought it was me not having tightened it up enough but after I did it again for a second box I was making I resorted to tightening it up after every series of cuts.
Now photos will follow when I get home today but my question is....
Should a router collet be left hand threaded? so that the spinning action of the tool would tighten it up rather than possibly loosening it and spitting the bit out at high speed (which I would assume would be scary at best, messy/fatal at worst)
It's made me a bit nervous about using the router as I would really like to keep all 10 digits (they pay the bills)
Am I being dim about this and should just use the gutentite method or is this a duff machine? (its a 1500W B&Q/MacAllister)
