Alex H
This is the side door to our barn.
It is made of wide boards, 3cm thick of hardwood, probably oak.
As you can see at the bottom it has rotted, however, the rest above the lower 20-30cm is solid.
I would like to repair it, but can't see how to attach the wood to replace the part I'm cutting out.
As there is no frame that holds everything together, what's the best way to go about this?
