johnfarris
Hi everyone
I am in the process of designing a internal door using sketch up, Once i have the design sorted i would like to eventually make it.
The door will have traditional mortise & tenon joints, and depending on cost i am going to use hardwood
I have started on the top rail of the door, but i am having trouble understanding the joint.
If you look at my pic you will see what i mean, It appears that 35mm is not thick enough but i have seen doors were this joint works
Any help would be very much appreciated
J
J
