to put in your electricity meter readings.
... but not until the first!!to put in your electricity meter readings.
The whole point of sending a reading -- which is likely to be out of the normal time-scale -- is to avoid them using an estimate!It does not matter what day you do. a few days either way will not make much difference unless your usage suddenly decreases. They will estimate back or forward.
Assume you are using 10 units a day on average for the last 100 days when the last meter reading was. So the meter reads 1000The whole point of sending a reading -- which is likely to be out of the normal time-scale -- is to avoid them using an estimate!
Assuming a reading a week before the price change, and an energy company failing to estimate usage at the old rate of £5 per day. Worst case overpayment would be £14 (7days x £2).
I'm guessing they can afford it.a £25 'inconvenience' payment.
If you read early or late they will still make an estimate of what the reading would have been on the change date. They wont as you suggest assume you have used no electricity between an early reading and the change date. The bigger the gap between the change date and the reading date the bigger the error will be with the estimate (especially as we are moving into winter) but a few days will not make much difference.What I was really saying in my initial comment was - take the READING on the first - when you SUBMIT it is less of an issue - there is no need for the 'supplier' to estimate at all. If you were to take the reading BEFORE the 1st and submit that then you would be charged at the new rate (not an insubstantial difference) for energy used prior to the rate change.
If you submitt a reading which you certify has been TAKEN on a specific date why would they estimate at all? You have given a reading and - well certainly with my supplier - you have to state the date of the reading, no question of 'adjustment for a different day' or 'no use'.If you read early or late they will still make an estimate of what the reading would have been on the change date. They wont as you suggest assume you have used no electricity between an early reading and the change date. The bigger the gap between the change date and the reading date the bigger the error will be with the estimate (especially as we are moving into winter) but a few days will not make much difference.
That will depend upon how vigilant your supplier is (physical readings taken) and/or how far ahead you have fraudulently reportedI've been saving electricity under my bed for the last month, so I can use it next month when it is more expensive. Otherwise known as putting in a higher meter reading than actual. Do you think anyone will notice?
I am sure there will be a lot of fraud about.I've been saving electricity under my bed for the last month, so I can use it next month when it is more expensive. Otherwise known as putting in a higher meter reading than actual. Do you think anyone will notice?
