chippy1970
I've got a job coming up this week that involves changing spindles on an old staircase. I'm fitting a new baserail but the customer wants to keep the existing handrail. The rail is the low profile type but has a flat bottom (no groove for spindles). I'm thinking of making some sort of jig to hold the domino flat and centred under the rail and I could put a domino in the jig so it pushes into the last hole to space the holes out. Then I could use the trim stop (if I had one) to domino all the spindle tops.
One worry is watching out for old nails in the handrail.
The big question is should I bother with any of the above or just glue and pin them in place or even pocket screw ??.
