Mortice gauge refurb
Shavingsnotdust
25 Jan 2023
Devon
I've dug out the mortice gauge from the box of tools inherited from my grandfather; made by Ridge and Sons it is a well-worn but looked after tool, probably rosewood with brass inserts . The reason I've not used it before is that it is missing both pins. I know there are some accomplished tool makers/restorers on here, so hoping someone could suggest a way to refurbish it. The pins clearly need to be of the right dimension and fairly hard - I'm trying to think of a suitable type of nail I might be able to cut down - and the question then is how to fix them into the holes in the brass. Given that brass is fairly soft, would a hard pin of the right dimension grip if simply pushed into the brass?
All suggestions gratefully received, especially if someone has actually done the job themself!
Seriously I've just used panel pins in mine when needed. Filed to suit. I usually file the ones for use across the grain into a triangular "blade" shape with a fine file.
If they go in to the hole tight, I'd leave it at that. Otherwise a drop, literally, of superglue.
They used to be gramophone needles, the old boys used what was available a bit of mix and match
Non of this ordering in parts, I am 3 gen plasterer and it’s much the same. Dad and g dad used to make their own wood flotes
When I inherited my great grandfather's tool chest I found this tin in amongst the various random tools, odds and ends. 20241125_210056.jpg20241125_210027.jpg
I've used old darts for pins. A bit heavier than gramophone needles. In fact have an old dart (flightless!) for scribing.
