Does anyone from Italy recognise this?
RogerS
20 Feb 2004
In the eternally wet North
This is a cabinet made in Italy from MFC (melamine faced chipboard or similar) with a very high gloss finish to imitate pink marble. I was wondering if this type of material was still available?
Many thanks
Roger
Are you sure its not white MFC that someone has marbled and lacquered? How regular is the pattern, thats usually the giveaway
Jason
Do you have a pic of the edge as a well marbled surface will have the figure of the marble carried around but edge banding will not.
Jason
Bit hard to tell with that fuzzy pic but the fact that the top moulding has all been coloured makes me think the sides have had the same treatment.
Jason
I can't see from the photos, but it is true melamine sheet or a "skin"?
Skins are widely used by Italian industrial forniture makers: they are a thin sheet of plastic that perfectly (....almost....) imitates wood, marble etc. and are applied with a vacuum sistem at relatively high temperature, so they can be applied on curved surfaces, mouldings etc.
Antonello...thank you for that insight. It sounds very much as if that could be the case here.
Which then gives me a problem as to how to replicate it!
