Raw69":2c1ddu2h said:I assume as long as I get the right angle when drilling, that simple dowels will work just as well. I have limited tools
Steve Maskery":2ryi62p4 said:My first BJ was a .....
Yep, perfect. The ideal way to cramp that would be to insert a removable fourth side at the bottom and use a few webbing cramps - RobSteve Maskery":2oi9b8aa said:For a design like that, yes, definitely. But it doesn't need to be overkill, a row of biscuits will do just fine.
Your bigger problem will be clamping it, I think.
Long mitres like this are a nightmare to do freehand, but if you concoct a really accurate jig to hold each section, then the job becomes a lot easier - RobMikeG.":14h9htgw said:Mitres aren't easy. I know they look easy, but they will test your planing skills to breaking point.
Wot Mike G and I said ^^ - RobQuickben":20n2inyw said:Biscuits appear to be good enough. I can stand on the table no problem and I’m a big lad![]()
As far as clamping, I used ratchet straps with blocks at the corners.
Register today and take advantage of membership benefits.
