Trevanion
Greatest Of All Time
It's a bit of an odd question but, has anyone here ever dismantled one of these?
Not my picture, but I've got a block with really worn, marred clamping faces from I presume cutters coming loose twice since both sides are bad. (Some nutter has just gone and ground off the worst of the marring and put it back to use after that :shock
I'm not particularly comfortable using one that's worn like that but the nuts and threads are in very good condition, at least they had a good spanner but shame they didn't use it to tighten the block :lol: . I've got another block which has pretty good clamping faces but the nuts aren't great and someone has drilled a hole in the end of one of the threads.
I've got as far as drifting a pin out and trying to get a thread loose but for the life of me cannot figure it out... Is it also threaded into the locking face which is threaded in along with the nut and then they grind off the end so you can't get it back out? There's guys here with 30-40+ years of experience over me and will have used these pretty extensively so I thought I'd ask the hive mind.
Yes, I already know I'm daft for using them. :wink:
