flounder
I was hoping I could get some advice from you fine folk regarding a fault I have with my router. I have a DW625E mounted in a table and it now has no speed control whatsoever, it just runs flat out regardless go which speed is dialled in. I have taken the speed control switch off and put an ohm meter across the terminals (there are three terminals two of which are also bridged by a capacitor). No matter which pair of terminals I measure across the resistance reading is constant and reads either 6 Mohms or 24Mohms regardless of the dial position. Now to me that would suggest that the switch is faulty and if it was just a basic potentiometer i would be confident about my diagnosis, but the switch clearly has more electrickery going on than just a variable resistor so wasn't sure if i am making an assumption with the lack of variable resistance reading?
Now my second dilemma is whether or not it is actually worth repairing! I can get a new switch for around £60. I bought the router second hand and although it has only had light DIY use over the last 2 years I don't know what has gone on before my ownership of for how long. I can buy a new DW625E for around £220 or a HitachiM12 for around £165. As it is going in a table permanently and I have a router lift i don't need a lot of bells and whistles and the Hitachi seems to have good reviews. So....is it with spending £60 to repair this router not knowing what other issues might be developing or should I bite the bullet and buy a new router with warranty etc. Are the Dewalt routers generally reliable over the long term?
Sorry for the ramble and thanks for any advice anyone can offer.
