Definition cuts
Do you mean the small radiuses advised by paint manufacturers on the joints in windows and similar on shaker doors?
I don't really do them but a router bit with a tiny radius or a couple of swipes with a block plane will do.
Ollie
Hopefully helps
Hopefully this will help
As lofty says, cut into the material to add these line details, blade selection will determine how much material is removed. A thicker blade will obviously remove more, creating a bold line whilst a fine blade will remove much less creating a more feint subtle line.
Ok, thanks for posting the pics, now I see what it is. :cool:
I have always just looked at that as normal internal cutting out with lines.
First attempt at definition cuts
Meant to be an Indian returning from the hunt
