Dalboy
What type of aids do you use to sand the inside of deep forms that have an opening too small to get your hand in safely but are easily seen by eye unlike small opening hollow forms. This also includes the type of sanding medium as I know some will not form to a curve very well and crease up leaving a sharpish corner which can lead to more lines being put onto the piece.
I did look at the simon hope system with the long reach handle but even then this was too large to get into one of the forms I turned.
Or do you leave it straight off of the tool whether it be a gouge or scraper.
I have used a dowel with foam fitted to the end to form a ball shape and attached paper to this.
