I was sanding the second bowl I had turned using 240grit Aluminium Oxide paper and I noticed dark streaks on the wood (see pic).
Am I right in thinking this is residue from the sand paper that is entering the end grain of the turned bowl?
If so is this normal and should I not use this type of sand paper?
I switched to using some Hope discs on a drill arbor and that got rid of the marks.
