- Joined
- 11 Mar 2009
- Messages
- 1,314
- Reaction score
- 11
I need to replace an exterior door on our house and it's a strange size. 814mm (3' 8") * 1992mm now it's the height that is the issue as this is 40mm less than the stock 2032mm * 813mm door size that is stocked by your Howdens type companies. What I am trying to understand is that it says max trim 6mm on each face, so 20mm is obviously a lot more, but if this is just so as to preserve the hardwood edge then it doesn't matter as it's on the top and bottom and the door is going to be painted.
I am more concerned with what these doors are actually made of. Is it a softwood core, or will I cut the lip off and find a honeycomb type structure?
I did contemplate making one or getting a local joiner to make one, but house is going on the market so trying to not waste too much on it.
If anyone has trimmed down these type of doors before I'd been keen to hear whether it will be ok to take 20mm off the top and bottom.
https://www.howdens.com/joinery/doo...-glazed-external-door-obj-sku-family-25352457
