lastminute
...need to cut an opening in my carport roofing to allow boiler vent kit through.
...looks awkward!
any ideas?
Gerry
...looks awkward!
any ideas?
Gerry
Yes but I was thinking about the pool that would form in the corrugation behind the flue. Might not be an issue I guess.phil.p":3m1bcy6g said:^^^^^^ + silicone.
Would be an issue as it would have nowhere to drain off unless you could fabricate a small bore pipe into it and lead that away under the carport, shouldn't be difficult using plumbing 20mm overflow pipe and fittingsBeau":drrahff2 said:Yes but I was thinking about the pool that would form in the corrugation behind the flue. Might not be an issue I guess.phil.p":drrahff2 said:^^^^^^ + silicone.
