Hi All
I want to make some oak panels 12" wide from rough cut boards which are 7" wide, i.e 2 boards wide per panel
I have rough cut them to length and planed a face edge on each board on my PT and I am almost finished thicknessing them on the PT but I have a few questions.
1. When thicknessing I have been placing the face side down on my PT so I am removing material only from the non face side- do I continue removing material from the non-face side OR when the faces are parallel do I take material from alternative faces to ensure even material removal?
2. When I get to the desired thickness do I then plane a face edge on ONLY the edges to be glued OR do I square both edges on both boards to be joined? If I am going to rip the glued board to final width then I guess I will need to have a square edge to run against my saw fence so I need atleast 3 square edges before gluing. I will probably hand plane the joint before gluing so will end up redoing the face edge I had already done on the PT
3. The glued panel will obviously be 14" wide is it normal practice to ensure that both boards in the finished panel are approx the same width when the board is brought to final dimension (i.e in this case would I then rip 1" off each side of the board)
4. OR should I rip the boards to final width BEFORE gluing so the finished panel only needs cut to length?
Andy
Andy
