cupping in pine
A
Anonymous
Guest
Could anyone tell me how to get rid of cupping in a piece of 2400mmx100mmx10mm pine, Cheers.
Derek.
Aragorn
6 Feb 2004
East Sussex
Plane it out on the jointer - this will reduce the thickness.
Thickness it out, concave face down first. This also reduces the thickness.
Cut a curf down the middle on the reverse side, almost all the way through and bend it out.
What's it going to be used for??
A
Anonymous
Guest
I am boxing some radiator pipes in and when i have come to put this piece on the top then run my router along with a flush trimming bit to square the edge up but their is a gap as the cupping is preventing it from lying flat resulting in a gap about 3-4mm all along the front my only other option is to cover it with trim which i don't really want to do.
Derek.
tim
5 Nov 2004
Herefordshire
If its 10mm thick I'd steer clear of the planer because there'll probably be not much left by the time the cuppings gone.
T
Frank D.
2 Dec 2004
Montreal, Canada
You can also cut it in half and reglue, if you're careful it will hardly show, then plane flat. Is it finished? If not you could try the lawn trick, place it out in the sun on some grass convex side up, and wait see what happens. It has worked for me, but with panels that have cupped. Keep an eye on it if you do this, sometimes it starts moving quite fast. Once it's straight get it back inside and finish as soon as possible. Another solution, if I understand the situation correctly, would be to just turn it upside-down so the gap doesn't show anymore?
Frank D.
Aragorn
6 Feb 2004
East Sussex
Yep - I'd go with Frank on this. Turn it convex side up and just nail (or screw) it in back and front. That'll take the cup out of a 10mm piece of pine!
tim
5 Nov 2004
Herefordshire
What Frank said - put a few cross battens between the boxing and the wall to use as nailing studs and away you go. One every 600mm or so should do it.
T
