arborealstudio
Hi All,
Just in the process of setting up a recently brought Wadkin BFT 12" planer. The cutter block has been removed and new bearings installed. I'll install the cutter block one the tables are coplanar. I've removed the tables for cleaning and they are now ready to be installed and levelled.
My question is on the best approach / method to level the infeed with the outfeed table. Also previously shims have been used on both tables. If there is no movement in the outfeed table does it need to be shimmed?
Can anyone also recommend a supplier of a straight edge for checking the tables and also a supplier of shims. The current shim are plastic, but happy to use anything that will get the job done.
Thanks,
Eddie
Thanks,
Eddie
