Concealed hinge for an internal fitting door
OllyK
10 Jul 2006
Derbyshire
Deftly side stepping all the questions about using standard or piano hinges, does anybody know where I can get a concealed hinge for a door that fits internally to the carcass rather than the more normal external?
I've tried the usual suspects of Screwfix and Hafele.
Hi most of the hafele hinges can be used internally you just need to order the ones with a 15mm crank
Jon
Blum also do what are known as "inset" hinges. Try the usual suspects - Woodfit, Isaac Lord and Ironmongery Direct. I usually get mine from Isaacs.
Just to saveconfusion re crank sizes. The blums have an 18mm crank which means you can use them with zero height mounting plates rather than 15mm crank/3mm plates.
Jason
