Shadowfax
This should be one for the PC technical guys amongst the forum members.
I have been experiencing a problem with Windows (!!). I am using XP Pro. What happens is that Windows is fine until one day it starts to open programs very slowly and then stops opening them at all.
If I do a system restore it generally gets things going again.
However, twice now I have had to restore the entire C drive from an external drive. That was the only way to get back to normal.
I have run all sorts of antispyware software. I have defragged the drive and I have run checkdisk.
NoAdware.net support have been assisting me by email but, frankly, they have been pretty useless up to now.
Does this sound like Windows getting shaky? In which case, as I have the recovery disk as well as a full XP Pro install disk can I just get back to a clean Windows install and then use the backup drive to reinstall everything but the Wndows folder? Or is that too simplistic?
I would rather not do this at all if it is possible.
Also, as the full XP disk is one supplied by a computer shop PC "mechanic" without a product key, can I use the key that belongs with the restore disk supplied by the machines' makers?
If not all I have available is the restore disk.
Does any of this ramble make sense?
Cheers,
Cheers,
