Competition Entry - Toybox WIP - IT'S FINISHED!!!!!
TheTiddles
14 Oct 2007
Wiltshire
Right then, time to start on this one whilst the copy-lathe is in work...
Just to remind you all...
Entry Level: Beginner, unless otherwise advised...
Design Brief: A toybox for my goddaughter designed such that it can double as an occasional table in the lounge where toys can be quickly thrown in to tidy up.
There is a design but that's on another computer, I'll add it during the week.
I started by getting some wood, I know I'm in the beginner category but I think this is definitely one of the best ways to start a woodwork project. The beech for the top and frame was purchased with the intention of ripping it up and leaving it indoors sticked up to dry for a couple of weeks, a couple of months later, here it is
It's very clean looking as the boards from that supplier are sanded smooth so you can see exactly what you are buying, but don't be fooled that they are straight and square you still need to do the usual work, so we did...
With that all done I started with the easiest bit, the top, which is just three boards joined together, I've used some biscuits for alignment which are cut with a router, this cutter is ages old, cost about a fiver and it really crappy, I need a new one as I just don't use them enough to get a machine specifically for it.
The piece is easily held secure with the iron hold-down from last year's Secret Santa, it's amazingly good for something so simple, must get a couple more one day. Please avert your eyes from the unfinished tool cabinet below, still awaiting knobs...
Using fizzy glue which on a warm day like today was going off rather faster than I would ideally like the parts are clamped with panel clamps first and then the extras just to squeeze it tight. I would like to add a note of appreciation to the local journalists, who do a fantastic job of supplying an easily located pack of thin glue protective membranes, though you really don't have to go to the effort of printing on them all, nobody's ever going to read it and take the staples out they just get in the way when separating them.
I haven't bought the wood for the panels yet, I was thinking spalted beech but given how light the framework will be maybe something darker like zebrano would be more striking, anyway, plenty of time for that now I've finally started...
Aidan
Always good to see someone making a start on their competition entry. :)
If you're interested, I've got a cheap Charnwood set for biscuit-jointing with a a router (I think it's one cutter and arbour with bearings that vary in width). I bought it last year but I know I'm never going to use it... I doubt it's even up to Trend quality so, could have it for £10 or something?
Facing reality, there's no way this project will be done as I've been without a workshop for a few months and I'm only just getting the new one up and running.
I'm out :cry:
Aidan
Bigger and better one?
Last night i was watching a bit of Johnathon Creek and the army had a huge aircraft hanger and i went oooowww aaahhh and i got a "that's not a workshop its an aircraft hanger" speech. She can't believe i'm outgrowing 750 square feet.
Right, time to get on with this again or I'll never win that prize...
Here's my rather incapable router setup for putting the dados in, a great cutter in a great router with a featherboard that is only facing the right way 50% of the time
This router table is scheduled for termination very soon, I've used it twice and it's totally rubbish, still, with a lot of holding on tight and three hours of Radio 4 podcasts there all done, the reason I didn't use a large diameter cutter on the side was the stop on the verticals, in hindsight I should have cut right through with the table saw and filled it later, nobody would notice.
Next stop is the mortices, not used these small chisels before, normally I use the large chisels on softwoods so I was going to clear them mostly with a drill bit first but after setting the depth
The chisel cut very nicely through the beech, I suppose the pressure on a chisel 20% the size of the largest should have that effect. The extractor having only one speed was guzzling air through the elephant's trunk which with the temperature just above zero today was enough to freeze my fingers
So all done except the mortices for the outside stiles of the front and back frames, I want to make absolutely sure the spacing is right so I'll probably cut the tenons on the rails before measuring the positions for the mortices.
So that's got you pros all aquiver now you've seen another helping of my fantastic entry, it's a winner for sure.
Aidan
You're nearly as slow as me....
Nice hold down.
TheTiddles":niwo5h32 said:
No surrender, VICTORY WILL BE MINE!
Having seen Aiden's project in person last night, I can assure all that it's in the bag...a re-run of the comp will have to be held 8-[ - Rob
Some small progress this week, I'm being very cautious as although unusually I have a full plan to work to I don't want to cockup one joint of a minimum of 4 and have to remake an entire frame. So I'm setting the rails into the stiles first, then cutting the vertical panel divider mortices then the panel dividers to make sure they fit.
Here's a simple setup to scribe the shoulders for the tennons without breakout, the stop is set at 40mm and the blade guards are removed for clarity... :lol:
The cleaning back of the shoulders is done on the woodrat, I was going to do this on a tennoning jig on the table saw but then I'd have to shift the stops for the scribing so creating a loophole for innacuracy to creep in. This is the first time I've used my T11 on the woodrat and what a difference from the T5, the 40mm stock removal was done in 3 passes instead of 20.
With the majority of material removed such that the tennon is a slightly too close a fit in the dado and socket I'm doing the fun bit by hand and fitting each one the old fashioned way.
Once I've got all the parts cut there's going to be a stack of these to do but that's a much more pleasant job that can have as much or as little time spent on it as and when I get to it.
By leaving the saw, router and mortiser all set up I should be able to get very repeatable results on these joints, although I have a mess in the workshop...
That's all for this week
Aidan
Hmmm, one year on...
I've just fitted the front panel rails together and joined the side panels to the back (just dry). I was going to fork out on a new giant mitre-lock router bit, but in the end I just added a rebate and a step.
Next, panels to be veneered and inside faces finished, I'm going to practive on some scrap beech first.
I laid the top on to see how it goes, over the last couple of years it's warped a bit and it doesn't sit well on top, it needs making smaller and maybe a chamfer underneath, we will see...
Aidan
A bit more progress this week.
I've hastily rebuilt my vacuum press for this, I've added three aluminium water bottles to act as an accumulator and switched the one big pump for two smaller, twin-head versions, the additional vacuum gauge isn't essential but it shows that I'm getting 12-13psi which is plenty
There are only two panels that are bookmatched, the centre front and centre back, just as well as I hate shooting veneers together, it never seems to go right, I ended up sanding these to get a hard edge. The substrate is 8mm exterior ply, I'm only intending to use a veneer on one side.
That said, even a thin veneer has made the panels bow so I'm going to have to put a balancing veneer on the inside where it will never be seen! Pity, as I only have some walnut left or break into a complete bundle of cherry, so lovely black walnut for the invisible insides. Here you can see the panels so far for the back, left and right, the final front panels are in the press left of the shot. They have been sanded back and sealed with shellac sealer and I'll give them a few more thin coats before a final finish.
The rails will be skimmed with a sharp plane and sanded prior to the finish being applied on the internal faces, I'm going to varnish this piece as it's going to get a rough ride for a few years. Will acrylic varnish go over shellac sealer on the panels too?
Aidan
Tramping along now...
I've dry-fitted the panels into the frames, there's just shellac sealer on the panels for the moment but I've ordered some Fiddes hard wax oil today and if that works ok on a sample area that's what's going on.
The drawer front is too large to to fit (thankfully) so is just presented to the front. Here showing the front matched panels. The top rail that sits just behind the drawer front has been dovetailed in on both sides and you can see in the background
and here the walnut backing veneer on the panels. It's flattened the panels nicely so they don't have a small gap at the midde from the bow. I don't really know how to fix the bottom rail in, I could put in a sliding dovetail from the rail side of the sides but then I can't assemble the frames separately and there isn't too much material there to work with. A very small tennon could be made but as I'm probably going to reinforce it with glue blocks anyway I'm leaning towards something crude like dowels. Thoughts?
This final shot is the back of the piece, I didn't have 12 leaves of the qilted maple, just 10 so the centre panel is the offcuts from the centre panel of the front, which is large enough by just a few mm, it's not ideal but it doesn't scream "odd" like using a different timber would have
Those panels look amazing, I don't know which side is better. I really like the walnut but the maple looks amazing as well.
The contrast of beech and walnut has convinced me to do that on the showerroom cabinet next on the list, thing is, I also have a bathroom and cloakroom needing cabinets... why can't anything be simple??
Right, a quite impressive 2 years from the start and closing on 3 years from conception... it's finished!
That is a cracking piece of work. The detail looks outstanding very jealous of your skills to make it. I love the idea of a pull out draw as opposed to a lid. Please email me the design drawings if you done any.
Well worth the wait, lovely piece! Really like that wood and its finish overall is excellent.
Good looking piece Aiden and your veneering has come out very well, nice job. Two comments/queries from me, the knob doesn't look quite right to me, it needs something bigger (handle rather than knob) which then leads to a query about how it works and its placement. What runners do you have in there and have you tried it fully loaded up? If it's a wood on wood runner with a small handle at the top it may jam or stick, might work better with a bigger handle in the middle
Good job though
Cheers Damian
