Competition 063/09 Syntec4 - Scalectrix Chest
Status
Not open for further replies.
Newbie_Neil
27 Jul 2003
Nottingham, England
Anyway, this will be only the 3rd thing I've ever made (apart from the workshop) so be gentle with me :oops:
SWMBO has been nagging me for ages about making something to put George my 5YRO Scalextrics sets in. He has 2 of the large sets and there are lots of pieces and Cars/Bikes to protect. I thought if I can throw in a curve somewhere I could combine this with the comp and provide something usefull too.
I started with Sketchup -something else I need to learn and came up with a basic box, with a curved lid. Nothing too fancy, but I'm a total beginner.
I bought the Pine for the box this morning 12"x1" boards. really nice stuff, much better than the rubbish that I normally work with from B&Q. The boards have some large Knots but I quite like it and it will go with the furniture that is already in Georges' room when finished.
I used Cutlist following recommendations here to calculate the best cuts and set to work trimming the boards to length and square.
I had planned to dovetail all the pieces on my new jog from Axminster. But all this changed when I realized that the boards were too big to fit in it :oops: However I need the practice cutting them by hand anyway, so I set about marking everything up.
I did make a mistake with one of the Pins, I cut it too narrow :oops: I had George in the workshop with me after School and I was distracted talking to him whilst cutting. Anyway, I'm sure I can fix it with a couple of wedges before final glue up. It was a good lesson learned anyway.
I now have all the Dovetails cut and test fitted. I then had to route a slot for the baseboard. I did not want the slots to be visible from the outside so I read a book that showed how to cut 'stopped dado's'. Looked pretty straight forward. I did this with a 6mm bit in the router with the fence thingy attached. Not too bad but had to look carefully for the pencil marks.
Last thing I did today was make a template for the curved lid. I made the template from a piece of 6mm MDF. I stuck a panel pin in the bench and tied some string to it with a pencil at the other end. This eventually gave me a radius for the lid of about 16" which looked ok. I cut this out on the bandsaw first. Then stuck the template to 2 pieces of the pine with tape. marked it out and used the bandsaw to cut out the pieces together. I might have a go with the router and use the template to trim the pieces tomorrow.
Have a look at my webshots site for some bigger pictures. http://community.webshots.com/album/548343579OVNEAB
Although I notice they have been having trouble, so it may not work.
Or look at my Blog http://theguitardoctor.blogspot.com/
Or failing either of them not working, try my own site http://homepage.ntlworld.com/lee_harrison944/Competition Entry/index.htm
Which is pretty reliable.
I hope its going to be very strong. Should be no problem for George to Jump on it :D
The lid will be curved anyway, so it discourage them from Jumping on it anyway.
Dedee- I have made a template for the curve, which I intend to 'plank' then plane/sand to a smooth curve.
If you look on my website you should get a better idea of what I mean. A picture is worth a thousand words and all that.....
Nearly There now.
Hinges Fitted and Danish Oil is touch dry.
Lid is finished.
applying the Oil
Handmade Hinges :D
At Last Its done!
Details:-
Made from 12"x1" Pine Boards.
Handcut Dovetails.
Mahogany Tray Runners and Joint Strips in the Lid.
Handmade Brass Hinges.
Cherry Ply (6mm) for the base.
'Coopered' Lid.
This is the 3rd thing that I have ever made, apart from the workshop that I made it in.
Couple of mistakes to mention. :oops:
I cut one of the Pins too small, hardly noticable but I know its there. Bit disappointed with that one.
I thought I had overdone it with the sanding, but once the oil was on I can still see some very slight marks if you get very close.
I wish I could have made it from some Hardwood, but cost is always an issue. especially as this needed to be quite big.
Things I learned:-
It is as hard as it looks.
But it's still worthwhile.
I like planing.
I need a Jointer Plane.
Poly glue stains fingers.
I don't like sanding.
I wont make any hinges myself again, unless they are wooden.
Measure 5 times and cut once :oops:
Dovetails take practice.
Even if its rubbish my Son will like it- Thats all that matters. See pic.
Thanks For looking. You can see the WIP on my website below or on my Blog http://theguitardoctor.blogspot.com/2006/03/wip-updated-pictures.html
Status
