Harbo":o9x6bqqa said:Yes Camellia oil for me - I use a felt wick dispenser and sometimes a spray for the bits you cannot reach.
For saws and cast iron I use a wax.
Rod
As I understand it, WD40 is a water dispersant and doesn't form a protective barrier on the surface of the metal - Robphil2010":2s3chpz7 said:Thanks ,so not wd40?
jimi43":3k0c85f9 said:I think that WD40 is wonderful stuff for mechanical things and is great for cleaning black plastic bumpers (try it!)...but for stuff that gets close and personal with wood....nah!
Camilia Oil (as far as experience has shown) does not impede or affect finishes and I think that WD40 will
Jim
woodbloke":pa130qqv said:I know that it says that on it's website but there's some technical reason that escapes me for the moment as to why WD40 isn't very good as a protective coating on metal.
Pete W":291xfphi said:woodbloke":291xfphi said:I know that it says that on it's website but there's some technical reason that escapes me for the moment as to why WD40 isn't very good as a protective coating on metal.
If you google WD40 you'll find more myths and urban legends than any other product I can think of. In rapid succession I read that it's useless when it dries, it never dries, it's only good for water displacement, its molecular structure allows water to penetrate, as well as the famous email listing 20 or 30 or 50 amazing things you didn't know WD40 could do.
On the other hand, I did find a couple of careful tests (on US gunsmithing sites) that compared WD40 with a host of products and it comes very high on the list for rust prevention. Not top, not the best, but very good.
I don't doubt that camellia oil is fine, but a quick look around places like Axminster and Classic Handtools shows it costs around £50 to £60 a litre. On the other hand, I can get WD40 almost anywhere for less than £10 a litre. Works for me.
I guess rust prevention is like sharpening. As Kipling said, there are nine and sixty ways...
Losos":2thncvj1 said:I'm now looking for something that will work on table saws, stay on for relatively long periods of no use, not stain the wood, and which can be wiped off if needs be.
I was using that and/or Singer (sewing machine) Oil, but at $NZ13 for a 100ml bottle, I felt it was a little expensive (= $130 per litre - about £55 - £60).GazPal":3jbn81fm said:Other than that, all I tend to use is 3 in 1 oil as rust preventative/inhibitor.
