Quantcast
Cleaning Jaws, whats best?
Weasel Howlett
6 Jan 2010
Malmesbury, Wiltshire
Can anybody tell me the best way to clean jaws. I have some internal and external sets that are jamming a bit due to some quite sticky gunk that im guessing is residue from different finishes. Im thinking i could use paint thinners to disolve it but want to know if this is a good idea and what oil or grease i should use to re-protect the surface after this is done.
Any advice greatly appreciated.
petercharlesfagg
23 Jun 2006
South Northamptonshire
James,
Your problem is one of those that I have NEVER ever had with any of my chucks!
What woods are you turning, sticky Pine, for example?
Whenever I clean my chucks, after dismantling everything goes into a bath of White Spirit to soak usually overnight.
Any heavy residue I remove with a wire brush.
Reassembling, I use graphite dust instead of grease or oil and the jaws are left untreated apart from a dusting of graphite on the threaded sections.
This treatment usually last for about 6 months even with some production turning.
Regards Peter.
Jonzjob
19 Mar 2007
Ex nr Carcassonne, S France. Now NW Wilts, UK
The last time I stripped and cleaned my K8 chuck I cleaned it with celulose thinners and then lubed it with some dry bike chain lube. Worked a treat. A liquid, but dries dry and doesn't pick up dust when back in use..
I'm with Pete in that don't use oil or grease. Use dry lubes!
