Clarke bench drill, is spindle nut reverse thread
Mel769
13 Aug 2015
London
Hi all, great forum and hope someone can help
Ive got this old clarke bench drill and need to remove the spindle nut which is located (at the top of the machine) in the hollow of one of the pulley wheels. I have finally found the right size socket (which is a 32mm, had to grind the sides down so it would drop in) but the nut's really stiff. Anyone know if it is a reverse thread on these spindle nuts ?? Thanks
Thanks for the response, i cannot see any tab washer. Left hand threads you turn counter clockwise (left) to tighten ?? Is that correct
