chuck insert adaptor
acewoodturner
28 Oct 2008
Glenrothes
I have a chuck that I use on my woodturning lathe which has a spindle of 3/4 inch 16tpi. I need to use it on my rotary device of my laser engraver which has a spindle nose of 10mm 1.5 tpi. A local engineering company quoted me big bucks to make an adaptor so I was thinking of just buying a 3/4 16tpi bolt and cutting off the head and then boring and tapping it. Does this sound feasable. I have found the bolts on ebay us but I can probably get them in this country which will cut down on postage. Any thoughts?
Mike
I would hold the bolt in the chuck to drill it out rather than use a drill press. Am I right in thinking it is a unf thread instead of a unc thread. The lathe is a Record btw. Anyone got any suggestions for a UK supplier of imperial bolts of this size?
Mike
To stand any chance at all to run true and in balance the adaptor insert needs to be turned and threaded in a one shot turning and screw cut process rather than tap and die.
Existing threaded bolts are never going to be true enough unless of a very high specification and alignment to cut the other thread would need a great deal of care.
I realise the chuck may only be used in an indexing mode but I would have thought stability was a premium requirement.
The alternate to a super precision adaptor is to ensure a normal Lathe scroll chuck (100mm?) secured via a 10mm diameter thread has a decent location and reference collar so that thread form errors can't influence its alignment, especially if the piece being worked is big enough to need a standard chuck.
Not quite the same thing, but I tried once making a disc sander using a threaded bolt and some drilling. Damn thing wobbled all over the place.
K
I'd bite the hand off the guy with the bizarre identifier! Having made several adaptors and/or modified threads on chucks, £25 sounds to me like a bargain - I'd want quite a bit more to do a proper concentric job.
Having a MW Lathe if I needed an adaptor like that I'd probably have a go myself but as I'd need to use a tap to cut the internal thread I'm not too confident of absolute concentricity. Good enough maybe. To be honest though I'm not a fan of single point threading, having only done it a handful of times!
Mike
Its complicated as chj says
I do it by selecting a piece of steel for the adapter in your case 1 1/8" dia
drill and tap for your male thread 10mm x 1.5mm pitch ( not tpi as you stated) and if theres a register machining that ....concenricitty isnt too important at this stage
then mount concentrically in the lathe a male thread the same size..
mount the blank and turn the outside down to the finished size in your case 3/4" with a 1 1/16" flange at the end
then turn the register and a run out groove
then using a single point cutter cut the 3/4"x 16tpi thread
deburr and jobs done
Ian
Hi Ian
Sorry for the late reply - man flu has knocked me out over the last few days! I would like to take you up on your kind offer. I will strip the tailstock off tomorrow and remove the insert from the oneway chuck. If you pm me your address I will post them off to you and include a fiver on top of the 25 for return postage if thats ok.
Mike
