CStanford":2fyk7f72 said:
Minwax Antique Oil is basically a Danish Oil but with more varnish resins. You get noticeable build in a couple or three applications. Four to five applications and you're basically dealing with a varnish.
Some of you fine fellows might want to give it a try.
Many Danish Oils
are Oil Varnishes. They are just laced with lots of solvents to obtain a wipe on/wipe off finish. It might take 5 or 6 coats to get the equivalent of one single brushed coat but you have less problems with dust, less rubbing down to do.
The proportion of resin to Oil content gives the hardness of the finished film. Short Oil varnishes (more than 50% resin) give a harder but less flexible film. Too much resin and they become hard, brittle and chippy.
Long Oil varnishes (less than 50% resin) tend to be more flexible. Marine varnishes tend to be long Oil varnishes because they have to put up with the weather/greater temperature variation and intense UV.
Liberon finishing Oil seems to be no different than a Danish Oil that contains resins. Coloron 'Danish Oil' certainly contains resins. As far as I know there is no one definition of 'Danish Oil'. Some may contain resin, some not.
If you want a hard wearing finish look to the floor finishes, especially those that are intended to be recoated relatively infrequently. Hard wearing virtually always means that there is something hard involved. That usually means something that looks (and feels) a bit plastic like. Most folk don't like the look or feel of such finishes on tool handles, so apply something that feels a bit more organic.
BTW. Anyone know what Stanley and Record were using on their Plane handles? My vote goes for Nitrocellulose. It's hard but cracks/chips like crazy, as anyone who has refurbed such Planes will attest. It's a clear example of a finish that it is hard but not tough ie. it can't take the knocks.
