FrikkinDust
I've been lurking for a while and gained such a lot from this site, so thought I'd contribute something back.
I recently wanted to build a cheap but decent 2x4 workbench and having googled a lot, I didn't find anything that fit the bill, so I decided to design my own. Thought I'd post it on here as I wish I'd have come across this post when I was searching. Maybe it'll help someone out. It isn't anything special, but was quick and does the job for now.
I made it to fit what I needed - 152cm x 65cm x 95cm (I'm 6'3'') Later I plan on putting in some drawers or some other storage.
All the wood (apart from the top) is cheapo 2x4 (or 38mm x 89mm actually). The entire workbench took 6 2x4s, plus whatever sheet material you decide for the top. Cut list and sketchup plan below. * note though - the extra apron at the front I didn't include.
Frame.....
Bit of extra support
Top. I used flooring chipboard, laminated to plywood. Then 15mm MDF just screw on top, through into the frame.
Trimmed the edges..
And fitted my vice. Job done.
![2.png 2.png](https://cdn.imagearchive.com/ukworkshop/data/attach/10/10867-2.png)
![3.png 3.png](https://cdn.imagearchive.com/ukworkshop/data/attach/10/10868-3.png)
![cutlist.png cutlist.png](https://cdn.imagearchive.com/ukworkshop/data/attach/10/10874-cutlist.png)
Frame.....
Trimmed the edges..
