space.dandy
Hi all,
We've recently moved house and I'm having some issues with hot water. I'd greatly appreciate any input on the subject. Our heating / hot water system is shown in the photo below. The boiler is configured to run central heating only, with the flow directed through two actuators to heat the water tank and/or the heating system as required. The boiler (hot water) is activated by a switched live (controlled by Tado) wired in series with the tank thermostat.
The issue we're having is that sometimes we run out of hot water in the mornings. The tank is 175L capacity, there's only three of us in the house and we don't take overly long showers. We've programmed the hot water to come on between 05:00 and 10:00 every morning and we normally shower somewhere between 07:00 and 08:00. I have no reason at all to suspect problems with the thermostat or Tado (the water is piping hot to start with) and nor do I think there is an issue with tank capacity as the wife can happily run a full bath at the weekend without issue. This is an intermittent issue, but it happened to me this morning: I was the last to shower and it was lukewarm by the end.
The only thing I can think of is that it's ambient temperature related. It was bitterly cold this morning, everything iced up and as you can see from the photo the boiler system is in the uninsulated loft space. Is the tank simply losing too much heat? Does it need better insulation?
Any advice gratefully received.
Chris
Chris
![tempImage1zWKK7.png tempImage1zWKK7.png](https://cdn.imagearchive.com/ukworkshop/data/attach/81/81405-tempImage1zWKK7.png)
