can you reccomend a water based replacement for pre cat?
ivan
4 Feb 2006
Devon
My modest spraying experience has always been with cellulose based finish. Can anyone reccomend a warterbased replacement that's more or less comparable with pre cat? I asked the Fiddes technical bloke last year and he said 'We do it, but you won't like it' so I didn't push my luck!
Thanks in anticipation, etc,
Ivan
Hi
I can't actually answer your question but know a man that might! Without knowing what you have or haven't stained the pieces with, and a few other details it's hard to suggest anything without you running the risk of a bad reaction somewhere along the line.
Try Morrells woodfinishes. (No, i don't work for them) They carry a thoroughly confusing array of products which most of the sales team seem to know only a bit about, but if you ask to speak to technical support they can usually offer some advice.
Good luck.
gavin e
Thanks, Gavin.
I did not have a particular job in mind, just interested in the possibility of changing to waterbased finishing. I have only room for a makeshift temporary spray "booth" (booth? Hahahaha!) better suited to non combustible products.....
