Jervisekken
CFM, Cubic feet pr minute (or a metric equivalent), is the number that tells you how much air your DC is transporting. Every machine in our shops has a required or recommended cfm, for example a 14-16 in bandsaw requires 400 cfm, a drill press and router table the same, and a 15 in thickness planer 600 cfm.
Some large vacuum cleaners are said by some to be able to be connected to a central collection system with ducting and all. I think even some manufacturers sell ducting with their vacuums.
Typically these machines deliver around 200 cfm. However, and very important, that is with "no load". Static pressure are lost in the ducting. Elbows and wyes and every foot of duct and hose contributes to this loss, so effective cfm can be considerably lower than the no-load-CFM. At least it is for the collectors that I have seen fan performance curves for. I haven't seen such curves for the vacuum extractors so can not tell for sure.
So, in theory the vacuums should not work in a ducted system, and indeed several people have reported here that they have given up this route. Still some claim they do work, even with planers and thicknessers.
Is anyone able to enlighten us on this topic?
