Moonsafari69
Hi,
A few weeks ago I made a Baffle Tube to reduce the noise from my CamVac 286W. This is the single motor type wall-mounting machine. As you all likely know these have quite a screech when in operation. The easy and simple approach is to install a 2 1/2" hose from the extract port at the top of the unit down to floor level preferably a few meters away. This does have good results.
That wasn't quite what I was looking for in terms of noise reduction though. A bit of searching led to the possibility of enclosing the CamVac in a MDF enclosure with sound proofing material on the inside. Again this was no use to me as it would take away the 'easy bag change' benefits of the wall-mounting version. Plus I'd question the heat gains if the unit were inside another enclosure.
So, I've come up with is a more simple acoustic approach. I mocked this us a couple of months ago using cardboard (very Blue Peter!) and it worked better than I expected. Two weeks ago I made a more robust and permanent solution using a section of new soil waste pipe and some 20mm deep convoluted acoustic foam. The process I used is detailed below and the results are nothing short of staggering:
In the photo below you can see I've used a new piece of waste soil pipe straight from B&Q, at 1100mm long and 110mm in diameter.
I used convoluted (egg box style) acoustic foam panels for the inside of the baffle tube. The panels are 400mm x 300mm x 20mm thickness and are rated up to 70'C continuous use. The thickness ranged from 10 to 20mm as it is convoluted. Three panels were made into a tube shape and put inside the waste pipe lengthways and the excess was trimmed off the bottom. When the 300mm edge is rolled up inside the waste pipe the fit is perfect and so tight it doesn't need gluing.
This is the view inside the Baffle Tube taken from one end. You can see the acoustic foam panels fit very uniformly. Note this is a photo that was taken today, so after 2 weeks (10+ hours of use of the CamVac). They are very stable with no change to how I originally fitted them.
This CamVac is designed to be used with a 2 1/2" or 63mm hose connection on the inlet and the outlet. To ensure there was no detriment to the airflow I made the narrowest points inside the Baffle Tube to be greater than the 2 1/2" or 63mm. The widest points actually go just over 80mm in diameter.
The top connection point is a rubber connector I found at B&Q too (same section as the waste pipe). This fits snugly into the waste pipe and creates a solid seal around the piece of 2 1/2" plastic duct. I fixed the length of duct so that it was maybe 100mm into the waste pipe. A length of flexible 2 1/2" hose was then connected to the duct and a black CamVac connector added to the end of that for fitting into the extract port. The bit of paracord is used to hang the tube up in the corner behind the CamCav.
As I've said, the difference this has made was a surprise to me. Bearing in mind the Baffle Tube is simply an open tube and wider than a traditional 2 1/2" hose. I've used this nearly every day for the last two weeks with 10 individual sessions lasting over one hour in duration. The CamVac itself does not get any warmer and the extract air is the same temperature after the hour as it was without the Baffle Tube fitted. I don't have a calibrated way of measuring the air pressures, however with the Baffle Tube fitted there is no difference in motor speed and the few simple experiments I've done suggest there's no difference in suction either.
The big difference though is in the sound levels produced:
Without using the baffle and the exhaust air venting directly upwards, the dB reading is between 81 and 82dB.
When the baffle is connected the sound level instantly drops by 15dB down to between 66 and 67dB. In the real world this is a huge difference, it's more than 50% quieter than it was before. I can now easily hold a conversation in the workshop with the dust extraction running, this was simply impossible before without very raised voices.
There will of course be the purist opinion that a baffle of any kind must have an impact on not just the sound levels but also the pressures and air velocities too. I'm an engineer, but not a scientist, so I can't say either way for certainly. What I can say though, is that after two weeks of use I have no fears of this having an adverse affect on my CamVac and will continue to use it. The benefit is beyond words for a small workshop situation where there is no possibility to have the dust extractor located in a different room.
There's enough info here should anyone else wish to make one. I'd imagine this idea would suit any type of HPLV dust extractor.
Hope this will be of interest to somebody.
![1.jpg 1.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38589-1.jpg)
![2.jpg 2.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38590-2.jpg)
![3.jpg 3.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38591-3.jpg)
![6.jpg 6.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38594-6.jpg)
![7.jpg 7.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38595-7.jpg)
![8.jpg 8.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38596-8.jpg)
![9.jpg 9.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38597-9.jpg)
![10.jpg 10.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/38/38598-10.jpg)
