Charlie Woody
Hi
I have a Camvac GV286 w, (wall mounted) twin motor extractor which has a 2.5" inlet. Recently I got a 100mm (4") cyclone from Chems of Cyclone Central thinking that I could change the 2.5" inlet to a 4" inlet so that when I run from the cyclone to the planer / thicknesser and to the table saw there will not be a change in hose diameter. Hopefully this will improve the suction.
I would then use a shorter piece of 100mm hose with reducers to 63mm for the Woodrat and 63mm then 38mm for the router table.
I decided to check with Camvac for any instructions to do this change over and they said : The new 4” inlet will be a straight inlet on your machine as the drum is too narrow for it to have a cyclonic inlet.
The 4” inlet hole will need to be in the same position as the 2.5” inlet you have currently so as to completely cover any open areas. We tend to seal and rivet the inlet to the drum.
So now I am in wondering if this means that the suction of my unit will disimprove if I change the inlet?
Should I keep the 2.5" inlet or change to the 4" inlet?
To say that I am confused would be putting it mildly :? :? :?
When it comes to techy stuff I am so dim #-o
Could somebody that knows about dust extraction please help me decide what to do?
